How to get Primary and secondry content from WTDocument
  • January 7, 2016
  • 3 replies
  • 2955 views
Hello I am using data base script to get the primary and secondary content of the WTDocument I am able to get primary but secondary I am getting issue does any one know how I can get the secondary object as well
7-Bedrock
January 8, 2016
ContentService should have APIs to achieve , did you check Javadoc?
adev1-VisitorAuthor
Hello Feng,
Actually I am looking for database script to get the primary and secondary objects
Can you paste your sql
adev1-VisitorAuthor
Hello Matthew,
I have come up with this which is giving me the result but I am not getting the Download url like we have in API ContentHelper.getDownloadURL, Can we download the file using the script ????
SELECT dm.name, ad.filename, ad.role
FROM wtdocument d, wtdocumentmaster dm, holdertocontent hc, applicationdata ad
WHERE hc.ida3a5 = d.ida2a2
AND d.ida3masterreference = dm.ida2a2
AND hc.ida3b5 = ad.ida2a2
AND dm.wtdocumentnumber='0000000021'
and d.LATESTITERATIONINFO = 1;
