How to get Review Comments in workflow
RS_10128209
Hi All
I want to get review comments and store it into a variable
and it need to the person in task at the time of performing rework
Please suggest me how can I do
HelesicPetr
(To:RS_10128209)
Hi @RS_10128209
Same question has been answered today for voting so it is same.
here is example from a task
wt.fc.collections.WTArrayList auditCol = (wt.fc.collections.WTArrayList) wt.workflow.engine.WfEngineHelper.service.getVotingEvents((wt.workflow.engine.WfProcess) ((wt.workflow.work.WfAssignedActivity) self.getObject()).getParentProcess(), null, null, null);
System.out.println("***Transition Expression: Audit = " + auditCol.toString());
java.util.Iterator auditEvents = auditCol.persistableIterator();
String comments = "";
while (auditEvents.hasNext())
	wt.workflow.engine.WfVotingEventAudit audit = (wt.workflow.engine.WfVotingEventAudit) auditEvents.next();
	System.out.println("***Transition Expression: User vote = " + audit.getEventList());
	System.out.println("***Transition Expression: User comment = " + audit.getUserComment());
PetrH
Hey @HelesicPetr Thanks for the reply
My object is Disposition Action
Internal name is wt.change2.disposition.DispositionAction action = (wt.change2.disposition.DispositionAction)primaryBusinessObject;
Pls refer screenshot highlighted comment I want to get
Could you please tell what changes I need to made in above code which you shred
HelesicPetr
(To:RS_10128209)
Hi @RS_10128209
If the comment is from workflow you don't need to do any changes.
the comment is saved on the workflow event not the DispositionAction
You just need to run the code from the workflow task, not the workflow robot.
If you need to run the code from workflow robot, you need to change a first row
wt.fc.collections.WTArrayList auditCol = (wt.fc.collections.WTArrayList) wt.workflow.engine.WfEngineHelper.service.getVotingEvents((wt.workflow.engine.WfProcess)self.getObject(), null, null, null);
remove the .getParentProcess()
PetrH
@_1647
(To:HelesicPetr)
@HelesicPetr wrote:
Hi @RS_10128209
PetrH
If in case we are using utility and taking pbo  as a parameter in helper class then how to get that comment?
If possible you can share snap of java code.
i got the other  details like role , owner, activity name etc  only "comment" I am not getting.
