How to get a variable dropdown list(Attributes like Plant location, some attributes) inside workflow task page? further to it, based on selected attribute value it should route to respective users.
Does it requires to customize the Work flow JSP template?, if yes kindly provide the code and source code location(path).
Hi Krishna,
A preferred way would be to create a custom enumerated class and defining your values in an RBinfo file. And when you create a variable in workflow, select type as “Other Class…”, and input the customized class.
e.g:
package ext;
import com.ptc.windchill.annotations.metadata.GenAsEnumeratedType;
@GenAsEnumeratedType
public class MyEnumeration extends _MyEnumeration {
* Enumerated class file for code enumeration.
* Refer corresponding RBInfo file for the changes
private static final long serialVersionUID = 1L;
ResourceInfo.class=wt.tools.resource.EnumResourceInfo
FirstChoice.value=FirstChoice
FirstChoice.order=10
SecondChoice.value=SecondChoice
SecondChoice.order=20
Example is for Windchill 10.x. This may require Info* Modeler. Let me know if this information was helpful
Bhushan
Hi Bhushan,
Thanks for your reply,
Can we achieve the same in Windchill 9.1M070?.
How to Fetch these Enumarated values to WT Document.
Kindly suggest.
Krishna
Hi Krishna,
9.1 has a separate procedure of creating enumerated class, customization guide talks about it. If you want to update these values to WTDocument attributes, in 9.1 Info* Engine task can be used.
Bhushan
Hi Bhushan,
I tried compiling the class. it is showing error: require information Modeler to compile..
Is there any other way to create enumeration list in wf task page.?
is there any option to use global enumeration list in the wf task??
Logeshwar.J
ITC Infotech India Ltd
Hi Bhushan,
As mentioned i created a custom enumerated type java (_MyEnumeration). i could compile the file.
class files are also getting created but when i try the Resourcebuild.sh command. output mesage: Build successful. but it is not creating RB.ser file in codebase directory.
RejectReason.java
package ext.pricol.workflow.dropdown;
public class RejectReason extends _RejectReason{
public static final RejectReason Price_Competency = RejectReason.toRejectReason("PriceCompetency");
public static final RejectReason Project_dropped_by_Customer = RejectReason.toRejectReason("ProjectdroppedbyCustomer");
public static final RejectReason Delay_in_Quote_submission = RejectReason.toRejectReason("DelayinQuotesubmission");
public static final RejectReason Project_Commercially_unviable = RejectReason.toRejectReason("ProjectCommerciallyunviable");
public static final RejectReason Project_Technically_unviable = RejectReason.toRejectReason("ProjectTechnicallyunviable");
public static final RejectReason Customer_Project_postponement = RejectReason.toRejectReason("CustomerProjectpostponement");
protected RejectReason() {
_RejectReason.java
import java.lang.reflect.Method;
import java.util.Hashtable;
import java.util.Locale;
import wt.fc.EnumeratedType;
import ext.pricol.workflow.dropdown.RejectReason;
import wt.util.WTInvalidParameterException;
public abstract class _RejectReason
extends EnumeratedType {
static final long serialVersionUID = 1;
static final String RESOURCE = "wt.part.partResource";
static final String CLASSNAME = new RejectReason().getClass().getName();
static final String CLASS_RESOURCE = "ext.pricol.workflow.dropdown.RejectReasonRB";
static Hashtable localeSets;
private static volatile EnumeratedType[] valueSet;
* WARNING - Removed try catching itself - possible behaviour change.
* Enabled force condition propagation
* Lifted jumps to return sites
static EnumeratedType[] _valueSet() {
if (valueSet != null) return valueSet;
Class<_RejectReason> class_ = _RejectReason.class;
synchronized (_RejectReason.class) {
try {
valueSet = _RejectReason.initializeLocaleSet(null);
catch (Throwable var1_1) {
throw new ExceptionInInitializerError(var1_1);
return valueSet;
public static RejectReason newRejectReason(int n) throws IllegalAccessException {
_RejectReason.validateFriendship((int)n);
return new RejectReason();
public static RejectReason toRejectReason(String string) throws WTInvalidParameterException {
return (RejectReason)_RejectReason.toEnumeratedType((String)string, (EnumeratedType[])_RejectReason._valueSet());
public static RejectReason getRejectReasonDefault() {
return (RejectReason)_RejectReason.defaultEnumeratedType((EnumeratedType[])_RejectReason._valueSet());
public static RejectReason[] getRejectReasonSet() {
RejectReason[] arrpartType = new RejectReason[_RejectReason._valueSet().length];
System.arraycopy(valueSet, 0, arrpartType, 0, valueSet.length);
return arrpartType;
public EnumeratedType[] getValueSet() {
return _RejectReason.getRejectReasonSet();
protected EnumeratedType[] valueSet() {
return _RejectReason._valueSet();
protected EnumeratedType[] getLocaleSet(Locale locale) {
EnumeratedType[] arrenumeratedType = null;
if (localeSets == null) {
localeSets = new Hashtable();
} else {
arrenumeratedType = (EnumeratedType[])localeSets.get(locale);
if (arrenumeratedType == null) {
try {
arrenumeratedType = _RejectReason.initializeLocaleSet(locale);
catch (Throwable var3_3) {
// empty catch block
localeSets.put(locale, arrenumeratedType);
return arrenumeratedType;
static EnumeratedType[] initializeLocaleSet(Locale locale) throws Throwable {
return _RejectReason.instantiateSet((Method)RejectReason.class.getMethod("newRejectReason", Integer.TYPE), (String)"ext.pricol.workflow.dropdown.RejectReasonRB", (Locale)locale);
RejectReasonRB.rbInfo
ResourceInfo.customizable=true
ResourceInfo.deprecated=false
# Entry Format (values equal to default value are not included)
# <key>.value=
# <key>.category=
# <key>.comment=
# <key>.argComment<n>=
# <key>.constant=
# <key>.customizable=
# <key>.deprecated=
# <key>.abbreviatedDisplay=
# <key>.fullDisplay=
# <key>.shortDescription=
# <key>.longDescription=
# <key>.order=
# <key>.defaultValue=
# <key>.selectable=
# Entry Contents
PriceCompetency.value = Price Competency
PriceCompetency.order = 10
ProjectdroppedbyCustomer.value = Project dropped by Customer
ProjectdroppedbyCustomer.order = 20
DelayinQuotesubmission.value = Delay in Quote submission
DelayinQuotesubmission.order = 30
ProjectTechnicallyunviable.value = Project Technically unviable
ProjectTechnicallyunviable.order = 40
ProjectCommerciallyunviable.value = Project Commercially unviable
ProjectCommerciallyunviable.order = 50
CustomerProjectpostponement.value = Customer Project postponement
CustomerProjectpostponement.order = 60
I could come up with the correct solution without the requirement of Windchill information modeler. I had similar requirement for this. As my customer doesnt have windchill information modeler. i was working on it. it is working for me.
Requirement:
I have bring drop down in the document for giving the reason for rejection.
Steps:
1. Compile RejectReason.java and RejectReasonRB.java (tis will have entry in the RB file)
2. resourceBuild the RB file to get RB.ser file. (if u wanted to add some entries using ENUMCUSTOMIZE in future)
Let me know if this works
Hi ,
I am looking for similar solution but the values should be multi select, can you please help me with any idea you have.
Thanks in advance ![]()
This is old but I had a similar requirement for multi-select and thought I would share what I did. Create boolean variables for each entry in the list. They display on the task page as a list with a checkbox, so you can select or not select any multiple of them. It works well if you have a manageable number of variables. No custom class required since using the OOTB Boolean type.
