Version: Windchill 13.0
Use Case: The "function validateComments" script contains a "document.getElementById("workitem_comment").value" expression. I think the "workitem_comment" value is being used to represent the ID of the field for the "Comments" attribute on a workflow task object.
Description:
I am trying to find out what the element ID would be for the "Process" attribute on the same workflow task object. Please can anybody shed more light on what an element is exactly and how I can query the IDs assigned to different elements that exist in Windchill?
