Hi.
I need to put created child parts to the parent part folder (all i do through java code).
If parent part wasn't checked out, then folder is defined corrrectly ( for example: wt.folder.Cabinet:103501<Default>) by code FolderHelper.service.getFolder((FolderEntry) parentPart).
But if parent part was checked out then FolderHelper.service.getFolder method returns something like that: wt.folder.SubFolder:48744<Checked Out>.
How can i get first result of checked out part?
Thanks.
Note that this happens only when parent part is at root level of a product/library. For a subfolder, this does not happen.
The fix is, get original copy of wtpart and then get its folder.
//Code
Folder folder = FolderHelper.service.getFolder((FolderEntry) wtpart);
System.out.println("folder = " + folder + " \nFolder Name: " + folder.getName());
WTPart wtpartOriginalCopy = (WTPart) WorkInProgressHelper.service.originalCopyOf(wtpart);
folder = FolderHelper.service.getFolder((FolderEntry) wtpartOriginalCopy);
//Output
folder = wt.folder.SubFolder:7771<Checked Out>
Folder Name: Checked Out
folder = wt.folder.Cabinet:7818<Default>
Folder Name: Default
//Code
//Output
