How to get started with Windchill 9 ? Can i customize it using its API's
vishnusoman
Hello All,
I have just had a very preliminary lok into PDT and Windchill and i find it quite interesting. I am interested to know the details and prerequisites (help links ?) to get me started with Windchill 9.
So the first question is can i have a zip containing the Windchill 9 intstaller ? I have read the Software Matrix and see Tomcat figuring there. So can the Windchill environent be set up on Tomcat ? I am interested in knowing these details for Windchill 9.
Any hints or pointers to getting started with the windchill installation would be really great.
VS
6 REPLIES 6
Also if i need to customize an installed setup of Windchill, can this be done using java programming and probably API's or frameworks used in Windchill ?
Yes, you can install WC from a zip. 9.1 uses the "solution installer." You'd run the setup file in the solution installer zip. This installer optionally references installers from other zips.
InfoEngine
PDMLink
ProjectLink
Third Party (apache/tomcat)
JDK
Directory Server
etc
http://www.ptc.com/WCMS/files/116125/en/WCContentOview.pdf (Content Overview)
http://www.ptc.com/WCMS/files/83421/en/GetStartWCInstallConfig.pdf (Getting Started With Windchill Installation and Configuration Guide)
http://www.ptc.com/WCMS/files/77023/en/WCExpressInstallConfigGuide.pdf (Windchill Installation and Configuration — Express)
http://www.ptc.com/WCMS/files/118054/en/WCAdvancedInstallConfigGuide.pdf (Windchill Installation andConfiguration Guide —Advanced)
"How do I customize Windchill" is hard to answer. I think the first step would be to see if the OOTB product meets your needs.
Hi Matthew,
Thanks for your reply. I searched around even more regarding PTC after i posted the query and now that you have mentioned the "solution installer" could you tell me how to obtain that. I have seen details of heavy and light licences so does it mean that the solution installer is not freely available and must be bought from PTC ? If so ,what would the cost for the same be ?
Thanks & Regards
VS
You can also contact a nearest authorized PTC reseller. http://www.ptc.com/appserver/wcms/partners/resellers/search.jsp
Hi Matthew,Dmitry
Thanks a lot for your confirmation.
Regards
VS
