How to get the WTPart from its related EPMDocument?
SaravananSubram
Hi All,
I can get all epmdocument which are linked with WTPart by following code:
Here "part" is variable.
QueryResult qr2 = WTPartHelper.service.getDescribedByDocuments(part);
But, Is there any way to get WTPart from its EPMDocument?. If possible, please provide sample code.
Regards
Saravanan
11 REPLIES 11
You could try:
wt.fc.QueryResult queryResult =
wt.part.WTPartHelper.service.getDescribesWTParts((wt.epm.EPMDocument)pri
maryBusinessObject);
Dax
You can also try below methods from *
com.ptc.windchill.cadx.common.util.AssociateUtilities* class
To get Active (owner link) part:
*WTPart activePart = AssociateUtilities.getActiveAssociatedPart(epmDoc);*
or to get all associated objects including WTParts,
*Object[] allAssocObjs = AssociateUtilities.getAssociatedObjects(epmDoc);*
Avinash <">http://avinashkor.cabanova.com>
<">http://www.linkedin.com/in/avinashkor>
On Mon, Sep 19, 2011 at 8:36 PM, Williams, Dax (GE Healthcare) <
-> wrote:
> You could try:****
> wt.fc.QueryResult queryResult = wt.part.WTPartHelper.service.getDescribesWTParts((wt.epm.EPMDocument)primaryBusinessObject);
> Thanks,****
> Dax****
> *From:* Saravanan Subramanian [
Dear Avinash,
Excellent!!!. Your code is working fine.
Saravanan
Thanks a lot Avinash. It’s working cool.
Yours Sincerely,
Samuel Shanthana Raja
Consultant-PLM/PDM Practice |BWIR|Chennai|India.
0091 44 43909300 Extn: 311| Email: samuelshanthanaraja.ramdoss@bwir.com<">mailto:samuelshanthanaraja.ramdoss@bwir.com>
Pleasure in the job puts perfection in the work.- Aristotle
I have used:
import com.ptc.windchill.cadx.common.util.AssociateUtilities;
import com.ptc.windchill.cadx.common.util.ObjectDependencyUtility;
WTPart wtpList[] = ObjectDependencyUtility.getAssociated((EPMDocument)epmdoc);
if( wtpList != null ) {
System.out.println( "\tAssociated EPMDoc length (wtpList.length): " + wtpList.length+"\n");
for (int y = 0; y < wtpList.length; y++ ) {
WTPart wtpAssoc = null;
wtpAssoc = (WTPart)wtpList[y];
System.out.println( "Found Existing WTPart Number Association to ("+y+"):");
System.out.println( "WTPart Number: "+ wtpAssoc.getNumber() + ", WTPart Name: " + wtpAssoc.getName());
System.out.println( "WTPart Version: " + wtpAssoc.getVersionIdentifier().getValue() + "."+wtpAssoc.getIterationIdentifier().getValue()+"\n");
that way yo get active & passive wtpart associations.
L Jett
All,
I know this is an old thread, however, I am trying to expand on it a little. I am specifically trying to get the associated WTPart(s) from the EPMDoc (primaryBusinessObject) and then set the LC state of the WTParts accordingly.
This is what I tried:
//get the object that is described by the epm document
java.lang.Object wtpart = com.ptc.windchill.cadx.common.util.AssociateUtilities.getAssociatedObjects((wt.epm.EPMDocument)primaryBusinessObject);while (wtpart.hasMoreElements()){
//set the state of the described object to RELEASED
wt.lifecycle.LifeCycleHelper.service.setLifeCycleState(((wt.lifecycle.LifeCycleManaged)wtpart.nextElement()),wt.lifecycle.State.toState("RELEASED"),true);}
When I Check Syntax I get errors:
D:\ptc\Windchill_10.1\Windchill\temp\WfExpression2985721454.java:30: cannot find symbol
symbol : method hasMoreElements()
location: class java.lang.Objectwhile (wtpart.hasMoreElements()){ ^D:\ptc\Windchill_10.1\Windchill\temp\WfExpression2985721454.java:33: cannot find symbol
symbol : method nextElement()location: class java.lang.Objectwt.lifecycle.LifeCycleHelper.service.setLifeCycleState(((wt.lifecycle.LifeCycleManaged)wtpart.nextElement()),wt.lifecycle.State.toState("RELEASED"),true); ^D:\ptc\Windchill_10.1\Windchill\codebase\wt\lifecycle\State.class: warning: Cannot find annotation method 'supportedAPI()' in type 'com.ptc.windchill.annotations.metadata.GenAsEnumeratedType'
Thanks in advance for any advise.
PLM Solution Architect
java.lang.Object is the highest level object in the java programming
language. You need to cast it to whatever the javadoc states. Likely some
type of map object is acceptable, but it likely returns WTHashMap or some
derived class of a mappable list/collection.
On Mon, Mar 30, 2015 at 9:31 AM, Cameron Swaner <->
wrote:
> All,
> accordingly.
> com.ptc.windchill.cadx.common.util.AssociateUtilities.getAssociatedObjects((wt.epm.EPMDocument)primaryBusinessObject); while
> cannot find symbol
> cannot find symbol
> *Cameron Swaner*
> PTC Solutions Expert
David, Thank you for your response. Can you provide a specific example or code that will help me fix this?Thanks,Cam
Sent from Outlook
On Mon, Mar 30, 2015 at 8:15 AM -0700, "DeMay, David" <ddemay@npss-inc.com> wrote:
wrote:
> All,
> accordingly.
> cannot find symbol
> cannot find symbol
> *Cameron Swaner*
If you have epm document then you can get the WTPart related to document below API
QueryResult qr= PersistenceHelper.manager.navigate(epmdocument, EPMBuildRule.BUILD_TARGET_ROLE, EPMBuildRule.class,true);
Iterate the QureyResult to get the WTPart
Is there a way by which we can get the related ID, just like this
   "ID": "OR:wt.part.WTPartDescribeLink:2221723", - when we do a get call for DescribedBy on part
There are numerous ways to get the desired results. When selecting the Windchill APIs, please make sure that the APIs need not be revisited when upgrading to the next build and the method is generalized in a way that it can be reused. Alos add exceptions handled and logger statement to verify the collected objects. Following is another elegant method:
//Initiate the collection result
Collection result = null;
WTCollection seeds = new WTArrayList();
seeds.add(epmDocument);
//Set the config spec
EPMDocConfigSpec configSpec = new EPMDocConfigSpec();
configSpec.setLatestActive();
//Set the navigation criteria
NavigationCriteria nc = NavigationCriteria.newNavigationCriteria();
List<epmdocconfigspec> configpecs = new ArrayList<epmdocconfigspec>();
configpecs.add(configSpec);
nc.setConfigSpecs(configpecs);
CollectedResult ccr = null;
ccr = CadCollector.newInstance(seeds, nc).associatedParts(GatherAssociatedParts.ALL).collect();
result = ccr.getCollectedObjects();
Iterator items = result.iterator();
while (items.hasNext()) {
Object item = items.next();
//Check for WTPart
if (item instanceof WTPart) {
WTPart collectedPart = (WTPart) item;
//Check if the WTPart needs to be set to the new state
//Set the State
Hope this helps
Thanks and Best Regards
Swamy Senthil
Principal Solutions Architect, Swasen Inc
swamy.senthil@swasen.com(Email) <">mailto:swamy.senthil@swasen.com(Email)> ; 909 800 8423 <tel:909%20800%208423> (M); 866 908 6561 <tel:866%20908%206561> (F);
_____
