Hi!
I need to check if the comment field is filled. I have this code, but it can only be used outside the transitions.
wt.fc.collections.WTCollection auditCol = wt.workflow.engine.WfEngineHelper.service.getVotingEvents((wt.workflow.engine.WfProcess)self.getObject(), null, null, null);
java.util.Iterator auditEvents = auditCol.persistableIterator();
comments= "";
while( auditEvents.hasNext()){
wt.workflow.engine.WfVotingEventAudit audit = (wt.workflow.engine.WfVotingEventAudit)auditEvents.next();
comentario = audit.getUserComment();
break;
if(comments.length() > 0){
throw new wt.util.WTException(new Throwable(new String("Você selecionou a opção Sem Comentário. O campo COMMENTS deve estar vazio!")));
Thanks!
