There is an IBA created in Part Usage Link to get some information about the Link object. I am able to add this IBA in Part Usage Link. But i want to render this IBA with a Drop Down list.
Will it be possible to render IBA (in a custom way) in the Part Usage Link in PSB
For your information, I am using Windchill PDMLink 10.2
Thanks in Advance.
Thanks & Regards
Gnanamuthu Lucas
Its unfortunate.Windchill 10.2 PSM using degisn by GWT and ExtJs . its not support Datautiliy.
I try to do this way. The datautility render result only display in "INPUT TEXT" value.![]()
You can add a data utility to your IBA using type and attribute manager.
Yes your answer is correct.
I tried to configure another way to register data utility. At that time my data utility is getting called by it is not rendering properly as i expected because of GWT ExtJs implementation on PSB.
Thanks for your reply.
