How to loop SQL "select WTKEY_SEQ.nextval from dual"
Hi guys,
In order to solve a problem of method server start, I have to do the request:
I have to do it until its value reaches 163553 but now it is only 139082. Each time I do the request, the value increments of 1.
I don't know very much about SQL and I would like to know if there is syntax to make a loop of this request until it reaches the correct value.
Thank you very much.
Florent
