1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 | //Apache POI package ext; import java.io.File; import java.io.FileOutputStream; import java.io.IOException; import java.lang.reflect.Field; import java.lang.reflect.InvocationTargetException; import java.lang.reflect.Method; import java.util.*; import org.apache.commons.io.FileUtils; import org.apache.poi.openxml4j.exceptions.InvalidFormatException; import org.apache.poi.openxml4j.opc.OPCPackage; import org.apache.poi.ss.usermodel.Cell; import org.apache.poi.ss.usermodel.Row; import org.apache.poi.ss.usermodel.Workbook; import org.apache.poi.xssf.streaming.SXSSFSheet; import org.apache.poi.xssf.streaming.SXSSFWorkbook; import org.apache.poi.xssf.usermodel.XSSFSheet; import org.apache.poi.xssf.usermodel.XSSFWorkbook; import org.joda.time.DateTime; import org.joda.time.format.DateTimeFormat; import wt.epm.EPMDocument; import wt.epm.EPMDocumentMaster; import wt.fc.PersistenceHelper; import wt.fc.QueryResult; import wt.pds.StatementSpec; import wt.query.QuerySpec; import wt.util.WTException; import wt.doc.*; public class Test2 { static int count=2;
public static void main(String[] args) throws WTException { QuerySpec qs = new QuerySpec(wt.doc.WTDocument.class); QueryResult qr = PersistenceHelper.manager.find((StatementSpec) qs); System.out.println("Number of WTDocument Masters: " + qr.size() + "\n\n");
WTDocument master = null; XSSFWorkbook workbook = new XSSFWorkbook(); XSSFSheet sheet = workbook.createSheet("WTDocument Sheet");
Map<String, Object[]> data = new TreeMap<String, Object[]>();
data.put("1", new Object[] {"DOC NAME", "DOC NUMBER"});
while (qr.hasMoreElements()) {
master = (WTDocument) qr.nextElement(); data.put(String.valueOf(count), new Object[] {master.getName(), master.getNumber()}); count++; }
//Iterate over data and write to sheet Set<String> keyset = data.keySet(); int rownum = 0; for (String key : keyset) { Row row = sheet.createRow(rownum++); Object [] objArr = data.get(key); int cellnum = 0; for (Object obj : objArr) { Cell cell = row.createCell(cellnum++); if(obj instanceof String) cell.setCellValue((String)obj); else if(obj instanceof Integer) cell.setCellValue((Integer)obj); } } try { //Write the workbook in file system FileOutputStream out = new FileOutputStream(new File("My_WTDocument.xlsx")); workbook.write(out); out.close(); System.out.println("it is written successfully on disk."); } catch (Exception e) { e.printStackTrace(); }
} } | cs |
