How to reassign a task to another user in Windchill ?
nkumar-10-11-122
hi
How to do that using API?
@rzemmali,
To do this grammatically (using API), you can use below code snippet:
ObjectIdentifier oid = ObjectIdentifier.newObjectIdentifier("wt.workflow.work.WorkItem:319469");
WorkItem wi = (WorkItem) PersistenceHelper.manager.refresh(oid);
System.out.println("WorkItem Name: " + wi.getIdentity());
System.out.println(" Workitem Owner (Before delegate): " + wi.getOwnership().getOwner().getIdentity());
WTUser user = wt.org.OrganizationServicesHelper.manager.getAuthenticatedUser("shirish");
WTPrincipal principal = (WTPrincipal) user;
wt.workflow.work.WorkflowHelper.service.delegate(wi, principal);
System.out.println(" Workitem Owner (After delegate): " + wi.getOwnership().getOwner().getIdentity());
I hope this will help you.
Shirish
