How to retrieve data from Flex PLM to be used in an Enterprise Solution application?
I have a query where I would like to retrieve data from Flex PLM 9.0 to be used in an Enterprise Solution application, how can I do it in FlexPLM?
To explain the complete scenario, I have a client who is using the FlexPLM 9.0. My application is Enterprise Solution application which needs data that has to be retrieved from the PLM. Now, to get data I would like to call a webservice/API for PLM of the client which will fetch data from the PLM and give it to me so that I can use that in my Enterprise Solution. So does the FlexPLM 9.0 have any such support where in I can take retieve data from it?
Can you please help?
Thanks in advance
regards,
Amey
