How to run multiple levels of RBD calcs at once in quality solutions
mciemian
In our RBD models we typically have multiple levels of indenture in the overall block diagram.   It would seem that running at the top level should automatically run all lower levels to get the proper results.  But it seems we have to run from the lowest level up individually to ensure there are results at all levels.  When now not doing this some results disappear or reset from the RBD Table.
Is this a setting somewhere or has anyone else had success running all at once?  Trying to determine what we might have done wrong.
rthomas-2
(To:mciemian)
not 100% sure if I understand your issue.
Look at this:
Calculate (F8); in the calculation section, go to RBD / Advanced. At the bottom, check "save linked diagram results".
If this check box is checked and you run a calculation at the top RBD level, the results will be updated and displayed on all RBD levels.
Thomas Reiter
