How to update "Modified Locally" files fromCommonspace
sdrzewiczewski
Select the Files > Add To Workspace
Unselect the option to use existing local files.
Steve D.
Quoting "Kelly, Andrew C" <->:
> Using Pro/Intralink 9.1 and Wildfire 4.0
> I've got objects in my workspace that show "Modified Locally" and
> "Modifications Not Eligible for Upload" status icons. I want to
> over-write the files in my workspace with the unmodified ones from
> Commonspace. When I check the files, then choose File --> Update, I
> get an error:
> Cannot update the up-to-date object. Warning: Object has naming
> conflict with the object in Workspace cache
> ... and the files are excluded from the update collector.
> How can I get rid of the modified status so that the files in my
> workspace match the ones in Commonspace?
> Andrew Kelly, P.E. | Senior Engineer | Crane Aerospace & Electronics
> | +1 440 326 5555 | F: +1 440 284 1090
0 REPLIES 0
