Hi can any one help me how I can update the WTDocument attributes I have some softtype also. currently I am using Update-Objects to update the objects I am looking for Windchill API
public static void updateAttributesValues(Persistable object, String[] attributeNames, Object[] attributeValues) throws WTException
if(attributeNames.length != attributeValues.length)
throw new WTException("The length of attribute names array is not the same as the length of attribute values array");
LWCNormalizedObject lwcNormalizedObject = new LWCNormalizedObject(object, null, null, new UpdateOperationIdentifier());
lwcNormalizedObject.load(attributeNames);
for(int i=0; i<attributeNames.length; i++)
lwcNormalizedObject.set(attributeNames[i], attributeValues[i]);
lwcNormalizedObject.apply();
By the way, LWCNormalizedObject is depricated in PDMLink 10.2.
WindchillJavadoc 10.2:
LWCNormalizedObject is deprecated and is planned to be removed in the next release. Use PersistableAdapter instead.
Hello Bjoern,
I am not able to search the PersistableAdapter class I am using Windchill 10.0 M010 can you tell me the package and if possible can you share code with me ?
The class is:
com.ptc.core.lwc.server.PersistableAdapter
The examples are the same:
CREATE
PersistableAdapter obj = new PersistableAdapter("com.acme.AcmePart",null,null);
obj.load("name","number");
obj.set("name","my name");
obj.set("number","12345");
obj.persist();
RETRIEVE
PersistableAdapter obj = new PersistableAdapter(my_persistable,null,null,null);
Object nameValue = obj.get("name");
Object numberValue = obj.get("number");
UPDATE
PersistableAdapter obj = new PersistableAdapter(my_persistable,null,Locale.US,new UpdateOperationIdentifier());
obj.load("attributeA","attribtueB");
obj.set("attributeA",Boolean.TRUE);
obj.set("attribtueB","PURPLE");
obj.apply();
PersistenceHelper.manager.modify(my_persistable);
In 10.0 and 10.1 there is LWCNormalizedObject.
In 10.2 the whole class in deprecated.
I wanted to update attribute on Document softtype. I found some solutions, however they are not working because I couldnt found required APIs in Windchill. I am using windchill 9.1
com.ptc.core.lwc.server.LWCNormalizedObject
if anyone found solution or any other way in 9.1, then Plz let me know...!
Hi Anurag,
Try below code.
* This method will update the IBA value without changing the iteration of
* the given Persistable object.
* @param iba
* The object of {@link IBAHolder}
* @param attrName
* Name of the IBA
* @param value
* Value of the IBA
* @exception WTException
* throws {@link WTException}
* @exception WTPropertyVetoException
* throws {@link WTPropertyVetoException}
* @exception RemoteException
* throws {@link RemoteException}
public static void updateValues(IBAHolder iba, String attrName, Object value)
throws WTException, WTPropertyVetoException, RemoteException {
final IBAHolder ibaHolder = IBAValueHelper.service
.refreshAttributeContainer((IBAHolder) iba, null, null, null);
// From part retrieving corresponding IBAHolder
final DefaultAttributeContainer defaultattributecontainer = (DefaultAttributeContainer) ibaHolder
.getAttributeContainer();
final AttributeDefDefaultView addview = IBADefinitionHelper.service
.getAttributeDefDefaultViewByPath(attrName);
final AbstractValueView abstractValueView[] = defaultattributecontainer
.getAttributeValues(addview);
final StringDefView sd = (StringDefView) addview;
final StringValueDefaultView svdobj = new StringValueDefaultView(sd,
(String) value);
// Putting StringValueDefaultView into AbstractValueView
.addAttributeValue(((AbstractValueView) (svdobj)));
// Updating the attribute container
StandardIBAValueService.theIBAValueDBService.updateAttributeContainer(
ibaHolder, null, null, null);
With Regards,
Kaushik
Thanks for quick reply!
I tried to modify WTDocument, but its giving error
wt.vc.wip.WorkInProgressException: The object is not checked out and cannot be modified.
above error coming when below statement execute
PersistenceHelper.manager.modify(wtDoc);
what could be reason?
Hi Anurag,
The error is saying to check out the WTDocument.
Without that it cant modify the WTDocument.
Kaushik
