How to use multiple value in data of "type" parameter in webject as OBJ of infoengine.
if my code is for example:
<%@ page language="java" session="false"%>
%<%@ taglib uri="http://www.ptc.com/infoengine/taglib/core" prefix="ie"
%><%@ taglib uri="http://www.ptc.com/infoengine/taglib/directory" prefix="dir"%>
<html>
<body>
<ie:webject name="Query-Objects" type="OBJ">
<ie:param name="INSTANCE" data="com.ptc.ptcnet.abukane2d.Windchill"/>
<ie:param name="authorization" data="$(@SERVER[] AUTHORIZATION[0])"/>
<ie:param name="type" data="wt.doc.WTDocument"/>
<ie:param name="where" data="()"/>
<ie:param name="attribute" data="number,name,version,lifeCycleState" delim=","/>
<!-- The "Return-Group" is named to outputSearched -->
<ie:param name="group_out" data="outputSearched"/>
</ie:webject>
<ie:webject name="Display-Table" type="DSP">
<ie:param name="GROUP_IN" data="outputSearched"/>
</ie:webject>
</body>
</html>
and for this in "type" parameter i want to enter more values wt.doc.WTDocument, wt.part.WTPart, etc.
so that i can create one report having multiple data displayed
The last time I worked on a report, I had tough time in figuring this out , but I got some support from an expert from PTC.
You can either do the below way or use the <ie:param name="TYPE" data="wt.part.WTPartUsageLink, wt.change2.ReportedAgainst,delim="," />
<ie:webject name="Query-Tree" type="OBJ">
<ie:param name="INSTANCE" data="$(properties[0]wt.federation.ie.VMName[0])"/>
<ie:param name="OBJECT_REF" data="$(parent[]obid[])"/>
<ie:param name="TYPE" data="wt.part.WTPartUsageLink"/>
<ie:param name="DIRECTION" data="uses"/>
<ie:param name="TYPE" data="wt.change2.ReportedAgainst"/>
<ie:param name="DIRECTION" data="theChangeIssue"/>
<ie:param name="ATTRIBUTE" data="number,name,obid" delim=","/>
<ie:param name="OUTPUT_TYPE" data="FULL"/>
<ie:param name="GROUP_IN" data="parent"/>
<ie:param name="GROUP_OUT" data="tree_out"/>
<ie:param name="DEPTH" data="9999"/>
</ie:webject>
Thank you,
Binesh Kumar
Medtronic - MITG
Hello Anant,
I moved your post to the PTC Windchill Community, where you'll have more chance of an answer on this I*E question.
Thanks peter..
</ie:webject>
Thank you,
Binesh Kumar
Medtronic - MITG
thanks binesh!!!!
