Version: Windchill 12.1
Use Case: I've created custom tabs in the UI(by clicking the “+” icon on the tab set) on WTPart, and I want to define the order of these tabs. these UI through created tabs are not defined via an action model as the other tabs. How do I control the order of these tabs?
Description:
I want the Details tab to be 1st and, Structure to be 2nd. How do I control the order of these tabs?
Hi @11025060
Thank you for your question.
Also, feel free to add any additional information you think might be relevant. It sometimes helps to have screenshots to better understand what you are trying to do.
In article https://www.ptc.com/en/support/article/CS336436 it tells us what type the tab is if it is configured in *-actionmodelss.xml
Is there any other value for the ‘tabType’ parameter if the tab is configured through UI, instead of the xml?
Can't you just click + drag the tabs to reorder them? I know you can do that for your personal UI, but I'm not sure if that affects other users for public tabs.
