Version: Windchill 12.1
Use Case: The position matrix of a assembly created in Creo needs to be viewed in windchill UI.
Description:
There are no columns available in windchill UI for the transformation matrix / Position Matrix in the structure tab of an assembly. How to enable this ?
you mean this :
Thats correct. Thank You!
