@Operation failed because the user did not have the necessary permission on the following objects to perform the operation: Format - jjk_cadform_b_stdrd_wm.frm, -.1
I recently installed Windchill 11.0. I am setup as Manager as well as User.
I sure can use some help on how to set the permission for drawing format in Windchill?
Best Regards,
GWC
If it's a new install and there is not yet anything in the system, start with just a .PRT. Create it and check in. Then find it in Windchill and right click, select Manage Security - add your name. Allows investigating existing permissions. Can also Set State to various states and repeat - see permissions by state.
Since it specifically calls out "necessary permission" then make sure your account is in fact the Manager of that context (assuming it's a Library for the Format). Look at the Team for the Library.
