not possible , see https://www.ptc.com/en/support/article/CS35571 .
use the unique attribute to seach documents and then move from search
I would recommend this method:
You can search for all document numbers separated by semicolon to get them all in one search result. Reference: https://www.ptc.com/en/support/article/CS19312?source=search
Then you can easily select all the documents from the search and move them where they need to go
@joe_morton is right. You can do hundreds of docs in a clip if you can get them into a search result or a folder. Then use multi-select.
One more option is to write an utility.
https://www.ptc.com/en/support/article/CS69568
Regards
Ajit
