Unable to set up Form Based Authentication
Version: Windchill 13.0
Use Case: Switch from basic authentication in OOTB Windchill to form-based authentication following Help center instructions: https://support.ptc.com/help/windchill/r13.0.2.0/en/Windchill_Help_Center/WCAdvDeployGuide/WCAdvDepAuth_ConfigAltAuth_FormBasedAuth.html#
Description:
First of all, when following the help center instructions, we couldn't found the resource without attribute in
<Windchill>/apacheConf/config/authResAdditions.xml file.
2- Where to put the configuration to let Tomcat knows that the app is configured with form-based, because it's not described in the help center page
3- The application url context does not redirect to the new form, it shows the following error:
ERROR : org.apache.catalina.core.ContainerBase.[Catalina].[localhost].[/Windchill].[MVCDispatcher] - Servlet.service() for servlet [MVCDispatcher] in context with path [/Windchill] threw exception [wt.method.AuthenticationException] with root cause wt.method.AuthenticationException
at wt.session.SessionAuthenticator.reauthenticateUser(SessionAuthenticator.java:251)
at wt.session.SessionAuthenticator.getUserName(SessionAuthenticator.java:157)
at wt.auth.AuthenticationServer.getUserName(AuthenticationServer.java:170)
at wt.session.StandardSessionManager.getAuthenticationName(StandardSessionManager.java:500)
at wt.session.StandardSessionManager.getPrincipal(StandardSessionManager.java:165)
The form is only displayed when requesting explicitly its URL: http://hostname/Windchill/login/login.jsp
But after put the wcadmin credentials, it shows the following error:
Any help please!
best regards,
