I would like to use the now being introduced Windchill File System to insert a Windchill drawing into an open AutoCAD drawing.
jlambertz
Allowing AutoCAD users to browse to files which they have access for insertion into their current drawing.  I understand this feature has been added into some of the Unite Technology tools.    This is a very common workflow for users.   They navigate to libraries and insert blocks from these libraries.  Currently, user must browse to library and either export or download.   Once that is done they navigate the insert command to the file downloaded.    Lots of steps.    Having their libraries in Windchill with access and revision control is just plan good document management.     Can you confirm this will be added in the next release or service pack for AutoCAD WGM?
0 REPLIES 0
