Is there any method to figure out just what the contents of a PTC CD is from the name?
For example: "MED-60318-CD-101_M030" and the rest as seen here:
Thank you.
ML Starkey
Refer to this page
http://support.ptc.com/cgi/support/apps/sft_upd_dsp/sft_upd_dsp_adv.pl?product=WNC
Binesh Kumar
Thank you! I wonder why this didn't come up when I searched the support DB . .. oh well!
That link no longer works, is there a new one that has a master index for all products?
Normally there is a 'version.xml' file inside each folder with the name of the CD.
This link ( http://support.ptc.com/cgi/support/apps/sft_upd_dsp/sft_upd_dsp_adv.pl?product=WNC ) works fine. However, the contents of this web page can be seen in the attached PDF file.
Not unless you know the file codes or have them stored in a file.
You can open the image and then open the version.xml file which will tell what the file is for.
The codes do not change, just the date codes when a new version/build comes out.
All that you listed are for Windchill 10.1 (101) with various build codes (F000, M030).
From your list, I have:
60171 - InfoEngine
60318 - Service Pack
60379 - PDMLink
60418 - Services
60419 - Third Party Software
60423 - Multi-Language Pack
60686 - Index Search
60702 - PTC Solution Installer
60703 - JAVA JDK
60704 - Business Reporting
607041 - Windows Server
607042 - Solaris
607043 - HP-UX
607044 - AIX
607045 - RH Linux
607046 - Language Pack
60707 - Workgroup Managers
60756 - Point Release
60757 - Help Center
60800 - Directory Services
Some you did not list:
60310 - ProjectLink
60319 - ECAD WGM
60430 - ProductView
60481 - Aphelion DS
60482 - PV Doc Support
60758 - ProductView Client
60795 - Product Analytics Process Advisor
60898 - Common Base
61006 - CPS sets
Hopefully you can fill in the rest or some else can.
Thanks, that is helpful. Anything to narrow down the subject and 'crack the code' here is exactly what I need.
