If the relation or link between WTPart and WTPartMaster is WTPartUsageLink then what is the relation or link between two WTPart objects ?
aachanta
Hi All,
Can anyone tell me the link between two WTPart objects.
if the Relation or link between WTPart and WTPartMaster is - WTPartUsageLink
                                   WTDocument and WTDocumentMaster is - WTDocumentUsageLink
                                   WTDocument and WTDocument is - WTDocumentDependencyLink
So kindly tell me the link object name ?
Thanks and Regards,
Aditya Achanta
bkontham
(To:aachanta)
Hi Aditya,
As per the below support article there is no Link object listed between the two WTPart objects.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS131357&art_lang=en&posno=2&q=part%20links&source=search
aachanta
(To:bkontham)
Hi Bhagirath,
I had seen that article before itself.
Like I was just thinking if there is any other link between two WTPart Objects ?
Thanks and Regards,
Aditya Achanta
satre-2
(To:aachanta)
Aditya ,
Below  are the two links between WTParts
  1. WTPartAlternateLink
  2. WTPartSubstituteLink
You can see wt.part Package in java doc it will give ou all link classes. Hope it helps
Shreyas
BineshKumar1
(To:satre-2)
If MPMLink is used, there could be Equivalent Links too.
