Hi!
I have exported all types and them attributes (all soft types for WTPart) through windchill wt.load.LoadFromFile utility. But when export is going on I have an exception like following:
com.ptc.core.lwc.server.TypeDefinitionLoader wcadmin - (endProcessTypeDefinition):
wt.util.WTException: Attributes ' —' and 'null' on wt.part.WTPartreferr to the same iba definition.
at com.ptc.core.lwc.server.cache.AttValidatorHelper.validateDuplicateIbaUsage(AttValidatorHelper.java:880)
at com.ptc.core.lwc.server.cache.AttValidatorHelper.validateAllAtts(AttValidatorHelper.java:859)
at com.ptc.core.lwc.server.cache.AttHelper.persistAttDefs(AttHelper.java:216)
at com.ptc.core.lwc.server.cache.TypeDefinitionManager.persistTypeDef(TypeDefinitionManager.java:895)
at com.ptc.core.lwc.server.cache.TypeDefinitionManager.updateTypeDef(TypeDefinitionManager.java:1509)
at com.ptc.core.lwc.server.StandardTypeDefinitionService.updateTypeDef(StandardTypeDefinitionService.java:193)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at wt.services.ServiceFactory$ServerInvocationHandler.invoke(ServiceFactory.java:399)
at $Proxy12.updateTypeDef(Unknown Source)
at com.ptc.core.lwc.server.TypeDefinitionLoader.endProcessTypeDefinition(TypeDefinitionLoader.java:804)
at wt.ixb.handlers.netmarkets.CsvIxHandler.invokeLoad(CsvIxHandler.java:543)
at wt.ixb.handlers.netmarkets.CsvIxHandler.createObject(CsvIxHandler.java:239)
at wt.ixb.publicforhandlers.ClassExporterImporterTemplate.importElement(ClassExporterImporterTemplate.java:415)
at wt.ixb.publicforhandlers.ClassExporterImporterTemplate.importElements(ClassExporterImporterTemplate.java:539)
at wt.ixb.publicforapps.Importer.importElements(Importer.java:1456)
at wt.ixb.publicforapps.Importer.importElement(Importer.java:1428)
at wt.ixb.publicforapps.Importer.doRealImport(Importer.java:1193)
at wt.ixb.publicforapps.Importer.finalizeImport(Importer.java:507)
at wt.load.StandardLoadService.importData(StandardLoadService.java:825)
at wt.method.MethodResultWriter.writeExternal(MethodResultWriter.java:151)
at wt.method.MethodResult.writeExternal(MethodResult.java:226)
at java.io.ObjectOutputStream.writeExternalData(ObjectOutputStream.java:1426)
at java.io.ObjectOutputStream.writeOrdinaryObject(ObjectOutputStream.java:1398)
at java.io.ObjectOutputStream.writeObject0(ObjectOutputStream.java:1158)
at java.io.ObjectOutputStream.writeObject(ObjectOutputStream.java:330)
at sun.rmi.server.UnicastRef.marshalValue(UnicastRef.java:274)
at sun.rmi.server.UnicastServerRef.dispatch(UnicastServerRef.java:313)
at sun.rmi.transport.Transport$1.run(Transport.java:159)
at java.security.AccessController.doPrivileged(Native Method)
at sun.rmi.transport.Transport.serviceCall(Transport.java:155)
at sun.rmi.transport.tcp.TCPTransport.handleMessages(TCPTransport.java:535)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run0(TCPTransport.java:790)
at sun.rmi.transport.tcp.TCPTransport$ConnectionHandler.run(TCPTransport.java:649)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:662)
Hi guys, thanks for your replys. I have solved it. The problem was there: in the wnc env, where i try to import data WTPart already have an attribute that I want to import. I have add this attribute 2 months ago and forgot about it. After deleting it, import have went nice.
Sorry, I have this exception when import is going on
Hello!
Not sure if this will help but we have found out in Windchill 10.2 M020 CPS4 you need to have the below settings in order to get it right:
<csvmode>3</csvmode>
<csvExportAncestorTypes>true</csvExportAncestorTypes>
Best regards,
Peter
Peter, what this mode will give?
Hello!
See below desciption for the different modes:
• 0—All localized values will be exported as part of the XML file. This is the default.
•1—All localized values will be exported into rbInfo files.
•2—Localized values on modeled types and attributes are excluded from the rbInfo files.
•3—Localized values on modeled types and attributes are excluded from the rbInfo files, and any invalid data, such as base definition objects that have been filtered from a type, is excluded. This prevents the subsequent import from failing because of the invalid data. (Only applies to systems which have been upgraded from releases prior to 10.2.)
Best regards,
Peter
Thanks Peter!
Most important when you are using this tool, attributes should exsists already on the target System! Only then you are able to import types and layouts of the types to the target system.
Maybe it will help you!
Vytautas
