In WPA, Currently when a regulation is getting failed based on the spec PPM calculation WPA is showing the substance category which is causing this failure. Our expection is we need to have the exact substances(along with their CAS Number) which is causin
psamuel-2
In WPA, Currently when a regulation is getting failed based on the spec PPM calculation WPA is showing the substance category which is causing this failure. Our expection is we need to have the exact substances(along with their CAS Number) which is causing this regulation failure. This needs to be displayed in the WPA Questionnaire information page for each and every spec.
0 REPLIES 0
