In Windchill 10.2 M030, apart from removing unreferenced file what are all different activities for managing the Vault size
mprasad
In Windchill 10.2 M030, apart from removing unreferenced file what are all different activities for managing the Vault size.
Vault file size has gone 98%, please suggest some system admin jobs to control the vault size growth.
BenLoosli
(To:mprasad)
Purge older versions/iterations or archive older versions are the only alternative to reducing vault size.
We have the vaults set to roll over to a new folder when each folder gets to 50K files. The threshold limit is a Windchill setting and is +/- 10% on the setting as to when it rolls over. The older folder is set to read-only so only the latest folder is RW. We are currently writing to folder 46 and I have setup/enabled 55, so I am good for a year or so. The 50K file limit is a practical one from a Windows OS stand point. MS does not recommend more than that in a folder due to limitations in the folder indexing.
