Index Solr - Problem result
ptc-1115172
I have a server with Windchill 10 M020 , PDMLink, ProjectLink to and Solr, which was successfully installed.
I carried out the process for indexing all the same files in Windchill through the"BulkIndexTool" and was successful.
I'm having trouble with the results of research, for two users with the same profile I'mdoing the same search results in different. Another problem is the use of "*" (wild card) that does not work properly and other things.
I wonder if someone is having a coma or had any problems indexing tool (solr)?
Rafael Rossi
0 REPLIES 0
