Info*Engine vs OData REST API
VladiSlav
Hello everyone!
Please tell me the differences between Info * Engine and OData REST API.
Which technology should be chosen and which one has great prospects?
Thanks in advance!
Best Regards!
1 ACCEPTED SOLUTION
DmitryC
(To:VladiSlav)
Hi VladiSlav,
Unfortunately, I've used only REST API so far, so I can't give you the functional comparison, but I can mention 2 other important things to consider:
1. Info * Engine is a proprietary technology, while REST API is de-facto an industry standard
2. There are plans to deprecate Info * Engine in the future Windchill releases
Kind regards,
Dmitry.
DmitryC
(To:VladiSlav)
Hi VladiSlav,
Kind regards,
Dmitry.
VladiSlav
(To:DmitryC)
Thank you very much for your reply!
Could you please write a source from PTC, where is it written that I*E will be deprecated?
I would like to study this issue in more detail.
Thanks in advance!
DmitryC
(To:VladiSlav)
Hi VladiSlav,
This solution acceptance was a bit premature - you might consider the functional capabilities of each integration method first.
Keep in mind that OData REST API has a domain for executing I*E tasks.
Here is the concern about I*E from before the OData REST API has been first released.
What I have been referring to is the I*E deprecation mentioned in the Windchill roadmap session during LiveWorx 2019. I may sift through the available videos for the proof. The official announcement might be delayed for a while until REST API catches up functionally with I*E. Also, I*E have been available for a while and have some default ERP connectors implemented, so I wouldn't worry about PTC discontinuing it in the foreseeable future or ever.
Kind regards,
Dmitry.
VladiSlav
(To:DmitryC)
Thank you so much!
