Installing and Configuring PDM/Link
Highlighted
R10 upgrade issue
Swamy,
Highlighted
R10 upgrade issue
David and Rohan
thanks for the pointers. Corporate ldap has two special characters in the
password. And due to this, there were two extra "\"s in codebase\web-inf\map
credential text file. Once we clean up the map credential file, the migrator
is moving ahead.
Thanks again for pointing the correct direction.
Best Regards
Swamy Senthil
Highlighted
R10 upgrade issue
Senthil,
In situations where you are using the same LDAP for both source and target,
restarting the Upgrade Manager could remove LDAP entries.
See the below workaround developed by Datafrond Team, resolution logged
within the Datafrond database. If you experience similar symptoms, try
applying the below resolution.
Upgrade Manager Fails at Step: Execute Standalone Migrators
WC10SERVER1
PTC Support Case 10540246 (Workaround)
Refer to an existing SPR 2095047, however differnet symptoms. Follow the
below workaround for Customer until PTC provides a resolution.
Customer Symptom: Each time you exit upgrade manager, pending users node in
LDAP gets deleted.
Workaround: As a pre-ugprade step, ensure that the pending users node exists
in the Windchill DS. If doesn't load the pending users data has been
modified to reflect the new domain - corp.cusotmername.com
Hemant Jatla | Datafrond LLC - hjatla@datafrond.com
