Intralink scripting - FINALLY AN ANSWER
lylebeidler
Ever since I started writing Intralink scripts, I have been trying to find a
way to read in the value for the current Table Configuration pull-down menu.
The reason for this is that I want to record the value, manipulate the table
configuration through the course of execution, and then set it back to where
it started at the end of the script.
I have finally found an answer.
This code will do it:
<start of=" inserted=" code=">
// FIND THE CURRENT TABLE CONFIGURATION NAME
// REQUIRES THE FOLLOWING IMPORT COMMANDS:
import com.ptc.intralink.component.ILToolbarComboBox;
import java.awt.*;
import com.ptc.intralink.event.ILEventManager;
Window activewindow = ILEventManager.getActiveWindow();
int boxX = 450;
int boxY = 60;
ILToolbarComboBox tableConfigBox =
(ILToolbarComboBox)activewindow.findComponentAt(boxX, boxY);
Object tableConfigCaptureObj = tableConfigBox.getSelectedItem();
String tableConfigName = tableConfigCaptureObj.toString();
// END TABLE CONFIGURATION NAME
<end of=" inserted=" code=">
This snippet allows you to then, at the end of the script, use this command:
IL.setTableConfiguration(tableConfigName);
To set the table config back to where it was.
Lyle Beidler
MGS Inc
178 Muddy Creek Church Rd
Denver PA 17517
717-336-7528
Fax 717-336-0514
<">mailto:-> -
<">http://www.mgsincorporated.com>
0 REPLIES 0
