Is anyone else having trouble with Check-In on IntraLink 3.3 M22 after the 5/3/2011 .dll fix?
scott_rockwell
We are having random check-in problems across the users.
Checkin fails - Check Conflict was unsuccessful.
The best we can figure it started around the 5/3/2011 .dll patch.
Symptoms vary somewhat, sometimes an initial check in will fail only to succeed on the second or third time.
Sometimes Intralink will mark the failed check-in files as Locked thinking a check-in is in progress - its not.
Sometimes .prt files will eventually go in but drawings and assemblies are being very stubborn and won't go in not matter what.
Sometimes it fails before the check-in form, sometime after.
I did check the PDM_INDEX and PDM_TABLE for adequate free space.
Running Intralink 3.3 M22. Clients are all on XP.
TIA,
ScottR
0 REPLIES 0
