Is it possible to add a link to Change Request in My Tasks table view in Windchill PDMLink
BikrantS
7-Bedrock
Is it possible to add a link to Change Request in My Tasks table view in Windchill PDMLink?
avillanueva
(To:BikrantS)
The subject column should be the primary business object of the workflow. Since My tasks is a general table, it is limited to things related to workflow tasks or action items. For tasks, that can only be the PBO. If the subject is a change request, then you should already have it.  If it is the change notice, then the answer is no since that is a few links away from the current task (Task -> Change notice -> change request). You would have to follow it.
I was able to fetch the CN number by creating an alias attribute on workitem with the below mapping.
MBA|primaryBusinessObject^WCTYPE|wt.change2.WTChangeActivity2~MBA|theChangeActivity2@WCTYPE|wt.change2.IncludedIn2~MBA|theChangeOrder2^WCTYPE|wt.change2.WTChangeOrder2
However, I am still unable find the mapping for CR. Please could you suggest.?
