Is it possible to throw Custom Conflict in event management window with retry option as skip
TDT
Is it possible to throw Custom Conflict in event management window with retry option as skip.
Attached Image is the OOTB Conflict, I want to throw a custom conflict like OOTB below.
d_graham
18-Opal
(To:TDT)
You can certainly throw custom conflict with the conflict stating anything you want using a listener.
TDT
(To:d_graham)
Hello @d_graham,
Can we also implement the option Failed With Overridable conflicts through Customization, So that users can skip and proceed with further action?
d_graham
18-Opal
(To:TDT)
I would think yes, but you when you overrode the conflict, you'd need a custom override which would break the references to other objects that are preventing the delete.
If it were me, I'd add a new custom action that did this forced delete rather than messing with the OOTB delete.
I wrote a class that did what I called "Power Delete".  The company wanted to delete objects from Windchill regardless of any references.  I warned them that they CAD data pointing to the deleted CAD objects would fail with missing component.  They replied that they were fine, so we proceeded with Power Delete. 😀
