I have a question about the "Remove from Cache" and "Purge Paticipant Cache" actions on Windchill's Participant Administration menu.
If I execute those actions, what will the consequences be?
Does the user's workspaces get cleared out?
Hi @GabrielPaes
It is safe to use. The function is used if you manipulate with ACL rules for access to the objects in contexts
Sometimes if you move user between groups or roles, the ACL ruleas are not properly changed because system uses an ACL cache somehow
so the function clears the ACL Cache. Not a Creo cache
PetrH
This should help:
Its just a cache to help improve performance. It should have nothing to do with workspaces.
Hi @GabrielPaes
PetrH
