Hi @AJ_9942604
Yes the API is still valid and works.
The requirement? Create own function with own code that set the effectivity by your rules.
For example the date is set based on a last release date.
PetrH
Hello is this API still valid? How did you achieve your requirement?
Hi @AJ_9942604
PetrH
Wow, not sure. That was 2012. I do not think I ever did anything with it. I will ask my former, thinner self.
