Issue while configuring Creo View Adapter for publishing Inventor files
AmarKarthi_Aras
2-Explorer
Hi All,
I'm trying to configure Creo View Adapter worker for publishing Inventor files in my PDM Essentials server.
I had installed WGM using standard Installation procedure and it identified my instance of Inventor 2013 and I checked in an Inventor Assembly into my PDM Server. I had configured the CAD worker with standard procedure and tried to publish for which I get ther error "Fails to start".
After a long troubleshooting I identified that when I try publishing my the worker is unable to start Inventor in my local machine(Which is correctly configured in Worker Agent Administration).
Can someone tell me is there any specific configuration that I need to do while configuring my Inventor along with WGM to sort the issue that I'm facing.
regards,
Amar.
Hi Amar,
There are some related solutions about this issue in PTC support.
https://www.ptc.com/appserver/cs/view/case_solution.jsp?n=CS116543&lang=en
https://www.ptc.com/appserver/cs/view/case_solution.jsp?n=CS36748&lang=en
https://www.ptc.com/appserver/cs/view/case_solution.jsp?n=CS29628&lang=en
In our installation the problem was solved by starting the process "workerdaemon" as application instead as service and configuring the file transfer as ftp instead of network shared folder.
At this moment our big problem is to publish certain assemblyes that make Inventor 2013 to crash unexpectly while publishing from Windchill (pubblish works fine if we pubblish the same assemblyes in manual way (using publish.bat command).
Regards
