Kathy,
I believe the patch is here :
<u>http://www.ptc.com/WCMS/files/85201/en/patch_8.0_all_1609956.zip</u>
However the install instructions say the patch is for M050 while the name of the patch is :
8.0-M050_M040_M030_M020_M010_F000_TP1.jar which seems to indicate it can be applied to other versions too.
Vincent
Thanks All!
On my workstation in the office I was able to disable the Java Plug In and everything works well. I have the latest version of Java 6 update 11 running in both 32 & 64 Bit Windows XP Pro, IE 7.0 and Foxfire.
Today I am working off-site on a laptop with Vista 64 Bit, IE 7.0 & Foxfire. I do not have the 'Java Plug-in' option on my Java Control Panel to disable. I uninstalled Java 6 update 11 and will try my Windchill at Java 6 update 7. Windchill 8.0 M050
Does anyone have any input?
Thanks in advance, Kathy
PS - we didn't install the patch. That has to happen at the server end which will not help me today...
We seem to run into this issue a lot. I'm trying to help support a client installation at the worksite while I am currently remote.I did check the Windchill matrix and 1.4.2_06/1.5.0_14 was the java supported, however I am actually running a higher version so it would be nice it the matrix was updated.
I don't have a problem with the multiple file find button applet on a running on a PC:
But I do run into the RMI Connection error on a laptop running:
SO my question is, what is the latest Jave compatabile with Windchill 8.0 M050?
Kathy
Time warp - I responding to Jessie and didn't even see my own posting earlier.
Who would have known that there are two Java Control Panels in Vista. I checked the control panel hidden View 32-bit Control Panel Items and there it was. So I disabled all but 1.6.0_17, un-checked my Java Plu-in and volia! I have my applet button working after only once going thru the RMI grant / deny process.
Dosn't help my co-worker back on 32 bit XP, but I'm up and running.
Kathy
