1) Which version of Java is supported by Windchill 9.0m050 and will it work with newer versions? We have a Windchill system tunning Java 7.15 and 7.67, as shown in Add/Remove a program. Do we need to roll back to some version of Java 6 or even 5?
2) When running File Server Administration, we get Application Blocked error message. Your security settings have blocked an untrusted application from running. Is this from the wrong Java version or something else? How do we clear the message or get the application to run?
We have removed Java7 from 1 of the client machines and it is running Java 6 now. However when we run File Server Administration, it wants to install Java7 again. Is there a Windchill setting to specify the Java version for the applets?
