LDAP and replication server
WayneBeck
8 REPLIES 8
Wayne,
Do you have the exact error threads from the logs? That might help, if we have that.
Alexius C. Chukwuka
IT Analyst, Global SAP Basis
Technical Change Management (TCM)
Deere & Company World Headquarters
400 19th St, Moline, IL 61265
Office: (309) 765-3133
Mobile: (319) 429-5336
JamesKerkstra
(To:WayneBeck)
I would check to make sure the vault did not go read only. But like Alexius said some logs would help.
James Kerkstra
[cid:image001.jpg@01CC93C3.9E6D22C0]
I did check to see if it had gone to read only. It has not. I have included a log file that has the connection error in it.
Because we care.
Wayne Beck
CAD/Windchill Analyst
IT
-<">mailto:->
Wayne,
Here is the problem
"wt.wrmf.transport.WTTransportException: Authentication to"
This is the url that windchll uses to authenticate to your replica server, in the log, authentication is failing as authentication is being enforced on this URL. The issue might be in the changes you made to the app-windchill-auth.conf is causing this authentication issue. Also are you using siteminder? Siteminder has also being known to cause this sort of issue, there is a siteminder file called localconfig.config that a lines in it for ignoreUrl, any url on these lines would not have authentication enforced.
Hope this helps,
Alexius C. Chukwuka
This is the error message I get when I try to broadcast Configuration.
[cid:image002.jpg@01CC93C9.7A2B4F30]
Looks like the problem was the security key. Thanks, all for the help.
Because we care.
Wayne Beck
IT
-<">mailto:->
Try regenerating your security key and put the new one on the replica and do broadcast reconfig.
Alexius C. Chukwuka
Ooops, look like you already did that and fixed it.
Alexius C. Chukwuka
