LOCAL CACHE SYNC
cspinelli
LOCAL CACHE SYNC
Good morning, we have a problem with local cache sync on Windchill 10.2; if I access Windchill from different workstations i presume that files should be the same but, for some reason, they are not. it seems that local cache cannot be synchronized.
do you have suggestions?
HelesicPetr
(To:cspinelli)
Hi @cspinelli
In the workspace there is a utility menu where you can synchronize information between local and server side.
The problem can be that the cache is corrupted .
Another point is that you should know that synchronization is not for updating older version in the workspace.
Sometimes you need to do a update if the workspace contains old versions of a object
This is normal behavior, that the user has to want to update older versions in the workspace.
PetrH
HelesicPetr
(To:cspinelli)
Hi @cspinelli
Yes delete the local cache
example "<user_profile>\AppData\Roaming\PTC\ProENGINEER\.wf"
PetrH
cspinelli
(To:HelesicPetr)
thanks but is it normal that the caches don't syncronize?
HelesicPetr
(To:cspinelli)
Hi @cspinelli
PetrH
