Latest iteration refresh
ptc-327042
Hi All,
I have a promotion request workflow in PDMLink 10.0 that has a rework loop using the following refresh expression
wt.maturity.PromotionNotice pn = (wt.maturity.PromotionNotice)primaryBusinessObject;
try
com.ptc.windchill.enterprise.maturity.PromotionNoticeWorkflowHelper.refresh(pn);
catch( Exception wte )
wte.printStackTrace();
The rework loop works fine if the promotion object is iterated once (i.e. from A.1 to A.2). The refresh will update the promotion request to be associated with A.2. But if the promotion object gets iterated more than once (i.e. from A.1 to A.2 then again to A.3) during rework, the refresh doesn't work and the promotion request will remain associated with A.1.
Shouldn't the refresh promotion objects expression be able to update A.1 to A.3? or is there some other way to do this?
6 REPLIES 6
There was a bug - please file a call for this.
I opened case #11238599. I'll post the results.
rmk
7-Bedrock
7-Bedrock
(To:ptc-327042)
Hi Bob,
Alternate solution, all the promotable object can be refresh by querying the Promotion Notice Targets. This works fine.
I have the same issue and fixed by this way.
Ramanathan.
lgrant
(To:rmk)
How do you "refresh by querying the Promotion Notice Targets"?
I kind of have the same issue with objects being modified during the review phase (not the rework loop) by a controlled group of approvers (who want to make a note on a document during the review!).
Problem is that this new higher iteration is not updated onto the resulting objects, so the previous iteration has its state set and not the highest.
JeffZemsky
(To:lgrant)
I just want the Refesh bit of code and I think that's the:
refresh(pn);
How would I use that?
