I forgot the adress to use when listing wt.properties file in IE. Something like http://<servername>/Windchill/netmarkets/jsp/site/codebase/wt.properties
You are very close the correct URL.
Use the following http://<servername>/Windchill/properties.html
Thanks, I wasn't aware that you could list all available settings. However, I wanted to list all settings made in wt.properties for our environment which is located in the codebase folder.
Thanks Ron.....aaah, it was that simple...
