Listening for Project State Events
ptc-5248447
Anyone know how to listen for state events on a project?
For example: If someone "Starts" the project then I would like to listen for that event and run some code.
I thought that maybe I can use ProjectEventType or even ProjectAuditEvent. But that doesn't seem to work.
hi,
set
wt.services.verbose=true
wt.services.verboseEvents=true
and check the ms log file. shows all events being emitted.
hth, martin
Martin, thanks for that information!
I was able to gather that we need to listen for an event key of 'ContainerTeamServiceEvent/STATE_CHANGE' after setting the wt property verboseEvents=true.
The Project2 class has a getCtmState() which provides the state information of a project which essentialy returns a ContainerTeamManagedState.
