MPMLink and Nested Process Plan Best Practice
BrianSullivan
Hello.
Does anyone have Best Practice documents willing to share? -
Trying to minimize amount of Work for the Manufacturing Engineer
MBOM to Process Plan to Work Instructions.
The MBOM can have Variants created using Option &Variants. Which really means that the Generic MBOM is Saved as a Subset of the Data under a New MBOM.
The MBOM is comprised of self container modules; which could each have a standard Process Plan and thus Work Instruction.
CAN I make Top Level MBOM Process Plan that Builds the Process Plans from the child Modules?
Wondering is anyone has documented the Technique Manually or with Options and Variants?
Do not want to Lose Part Allocations...
Brian Sullivan
Brian,
Did you come up with anything on this?
