We've been trying to manage our Creo Start/Setup Files (Creo Templates, Formats, Materials, Notes, Symbols, etc.) in Windchill...
Benefits to using Windchill:
Headaches to using Windchill (over a network drive)
Any tips? Best way manage these files? Windchill? Network drives? Other?
“If users don't name the Windchill server exactly (case sensitive) as setup in the config.pro, none of the setup files are available. Example: start_model_dir wtpub://PDMLink... Is there a way around this? We've created a Creo mapkey to add the Windchill server but users don't always use that.”
We don’t have to force a common server registration entry name. We can extract whatever name they used. Users need to launch Creo, register it with Windchill, and then restart Creo for this to work.
Use a Creo launch command to:
This file may not exist if the server registration was deleted or Creo hasn’t been registered yet.
Creo 3.0: %PTC_WF_ROOT%\ .ssappd\ServerMgr\.srv_mgr_db3.fldx
Creo 4.0: “appdata%\PTC\Creo\Platform\ServerMgr\.srv_mgr_db3.fldx
The structure of this file can vary, especially if there are multiple registered servers or if users regularly take Creo online/offline. Also, we don’t want to modify the file. Altering it can corrupt the server registry. We just want to read out the values we need.
Hint: Powershell is good at parsing XML documents and extracting the information we want (e.g. active_server.name and active_server.location).
set WCActiveServerName={value extracted from .srv_mgr_db3.fldx}
set wc_stds=wtpub://%WCActiveServerName%
start_model_dir $wc_stds/…
Agree this is frustrating.. I'd like to use Windchill, but it doesn't work well for this.
Here's the solution we've implemented:
The advantage of this is that if a user is working offline or doesn't have access to Windchill, they still have access to all the settings and templates. Every time they start Creo, their system will get any updates (so long as they have network access).
The only exception to this is our formats - those are managed in Windchill. We had issues with copies of formats getting checked in.
@joe_morton Do you have to also run a script to delete any removed files from the users computers? Our IT was able to write a script to copy Creo setup files when a person starts their computer but removing copied files is harder than copying. They can also manually launch the script.
We have locations across the globe which results in high latency access to network drives. If you are copying hundreds of small files (Creo material files, ModelCheck files, etc.), copying can take several minutes... which would be undesirable to use at Creo startup.
There's a flag you can use on robocopy - /purge - which will delete any files from the local directory that isn't in the network drive. Robocopy will need to check each file, but "By default Robocopy will only copy a file if the source and destination have different time stamps or different file sizes."
Also, I highly recommend setting retries to 0 - /r:0 - otherwise, robocopy will try up to a million times to download the file until it gets it.
Here's all the details on robocopy: https://ss64.com/nt/robocopy.html
For our setup, we have several network drives semi-local to our different sites. I make sure to update all the network locations (eventually I want to get this scripted so it's automatic), but then the users have a more or less local network drive to get their files from. It's basically like manually maintaining a replicated vault.
