Managing Creo Setup Files in Windchill Headaches
We've been trying to manage our Creo Start/Setup Files (Creo Templates, Formats, Materials, Notes, Symbols, etc.) in Windchill...
Benefits to using Windchill:
- Windchill provides lower latency versus using network drives when trying to access Creo start/setup files from multiple countries (with Windchill replication servers).
- Windchill provides a history of the files with check in comments.
Headaches to using Windchill (over a network drive)
- If users don't name the Windchill server exactly (case sensitive) as setup in the config.pro, none of the setup files are available. Example: start_model_dir wtpub://PDMLink... Is there a way around this? We've create a Creo mapkey to add the Windchill server but users don't always use that.
- Adding/Editing files must be done through a Creo Workspace>Import and creates a Windchill Type = 'Other' CAD Document.
- Creo must have the allow_import_file_extension txt,tbl,mat,mtl,sym set to allow importing the various Creo setup files.
- Since these files are managed as some sort of Creo CAD file in Windchill, cannot have a space in the same otherwise the import fails.
- Creo cannot see regular WTDocuments even if the file content is a Text File or some other file type Creo can use outside of Windchill.
- Not surprising, you can only have the same file name once in Windchill. Using network drives, it's possible to put the same file in multiple locations if desired.
Any tips? Best way manage these files? Windchill? Network drives? Other?
