We recently went thru an exercise developing how we will manage patents in Windchill going forward. The key needs that we see are:
a) Manage the listof allpatent numbers apply to the business and make the patent documents readily available, along with their status (e.g. MOI status only, patent Pending Issue, PatentIssued, Patent Expired).
b) Manage the relationships between patent numbers and the Part Numbers / Product End Items where they are used.
To this point, we have used a ProjectLink project with a very simple process. In the project, we've stored all PDF's of patents (issued by external parties) as regular WTDoc's, and used aspreadsheet also stored in the project with manual entries for all columns.
Going forward we intend to use the following. Hoping to get ideas on optimizing this from others prior to implementing. Note: Happy to send details of this to anyone interested (we have a detailed Word doc and PowerPoint on it).
1. Create Subtype of WTDocument called Patent Document; apply several attributes: Docket Number, Issue Date, Inventors, etc.
2. Create Library just for these documents (all are actually .pdf, issued by external parties); folder specified in OIR at Org level for this type exists only in this Library - prevents them from being created anywhere else.
3. Apply a simple Lifecycle to this subtype with these states: Issued, Reviewed, Expired. Library Managers use simple Set State action to change states (may make this Promote in the future).
4. Create a saved Search available to all with Search Table View specific to patent documents with all attributes as criteria;Query Builder report also specific to Patent Documents, with all attributes as parameters.
5.Create ProductView watermarking specific to these states (document collaboration option in use by all).
At this point, we had all covered but the relationships. In general, we need to build relationships between the patent documents and one or more WTParts, without changing (iterating) either. One possibility is to create another WTPart to which both are linked. This didn't seem optimum. Exploring all other methods, we came to the conclusion that using Baselines was the best we could think of as the "glue" between the patent doc's and the Parts to which they applied.
6. Process: For each Patent Document, create a Baseline, named "<patent number="> usage." Make the patent document the "top object" of this baseline. Add all WTParts on which this patent is used to the Baseline. Manage the Locked and Protected status of the Baseline (tbd here).
7. CreateQuery Builder report for the baselines, with a criteria that filters on the Name, returning only this type of Baselines. In the report,includinghyperlinksto both the patent documents and all WTParts in the Baseline, providing single click access to the document and all related WTParts from the report.
Note -WTParts can be: End Items, Label parts on which the patent is listed, software in which the patent is displayed, other parts (generally assemblies) whose design relies on the patent.
So, just interested in any other comments before we implement in production - from both other users and PTC.
thanks in advance
Mike,
Your solution concept sound quite valid. I am interested in more understanding of step 5; particularly why you feel that the creation of the part/patent associations should notiterate either object? The baseline approach appears, on the surface, to be more complex than necessary just to avoid iterations.
Russ
