Massive Undo Checkout
pwilliams-3
10.1 M040
Hi Everyone,
Is there a command line tool that can be used to undo checkout on all EPM Documents in preparation for a migration or upgrade?
Patrick Williams | Engineering Systems | c: 616.947.2110
[cid:image001.jpg@01CFC90A.E3C92560]
Patrick,
I remember using "wt.epm.upgrade.DeleteAllFromWS" to check if there are any
item checked out. It also had an option to execute mass "undo check out".
It was available on Windchill 9.X. I believe, the syntax was something like
the following:
- Generate a list of checked out/new objects
windchill wt.epm.upgrade.DeleteAllFromWS -check all
- Execute mass "undo check out"
windchill wt.epm.upgrade.DeleteAllFromWS -clean all
The utility used to write information to following location:
<wt_home>/logs/UndoCheckedOut.log
Please check if this utility is still available.
*Note:*
- "premigrate-80.jar" used to contain this utility
Rochan Hegde
Productspace Solutions Inc.
Cell: 630-495-2999 x 8121
On Fri, Sep 5, 2014 at 12:11 PM, Williams, Patrick <
-> wrote:
> 10.1 M040
> Hi Everyone,
> *Patrick Williams* | Engineering Systems | c: 616.947.2110
> [image: sc_inc_black_sig_1_alt]
Hi Patrick,
Maybe you have another reason to force a massive'undo checkout'. An upgrade as such doesn't ask for it (as far as I know).
Regards,Hugo.
<< ProE WF5 - PDMLink 10.1 M040>>
Yes I do have another reason. I am modifying all containers in the system with a few role changes. However I cannot remove principals from a role if they have work checked out.
Patrick Williams
On Sep 7, 2014, at 3:27 PM, "Hugo Hermans" <-<<a style="COLOR:" blue;=" text-decoration:=" underline&quot;=" target="_BLANK" href="mailto:-">>">mailto:->> wrote:
Hi Patrick,
Maybe you have another reason to force a massive 'undo checkout'.  An upgrade as such doesn't ask for it (as far as I know).
Regards, Hugo.
You want to lose the data I presume? The checked out copies?
WIP copies are stored alongside previous iterations. This may be faster done with SQL then with code, that would be the route I’d go. You then have to also remove it from the user’s workspaces.
This is easier to do if you know the users you want to remove from the container team roles.
I’d go with the WTUser, Cabinet and EPMWorkspace, then also the ControlBranch and WTPart, EPMDocument, WTDocument (whichever) tables. FolderMemberLink shouldn’t have any in them I believe.
Hi Patrick,
This must be possible from the UI itself when logged in as the Site Admin or Org admin.
I dont remember exactly, but some where in file server admin or similar area.
But, you will lose the checked out copy from the server.
rgds
Hari
